1995 Contour 2L 4cyl.143,000mi.Cooling fan not coming on.
Feb 20, 2007 at 10:53 AM
Check whether the cooling fan is locked up and apply power directly to the fan to see if it runs. The coolant temperature sensor is the most common cause; the multifunction relay box can also fail.
The owner of a 1995 Ford Contour reports that the cooling fan does not come on. The expert advises checking for a seized fan and powering the fan directly, noting that the coolant sensor is usually at fault and the multifunction relay box can also be bad.
