Contour Constuction
GAUZER
So I began today what used to be a fairly easy process of removing a starter. Not with this car. The starter is in such a wierd position that I cannot even see the mounting bolts, much less get a wrench on them to remove the damned thing. And the plastic around the nuts for the terminal makes it impossible to get anything in there to remove the cables. Does anyone have any ideas or tips for this task?
Aug 16, 2007 at 9:10 AM
SHELBYGT
  • 56 POSTS
man i know what you mean its an the back of the engine, i had alot of scraped knuckes and alot of bad words but after a few hours of just messing with it i finally got but put it on is a pain to i'm sorry i wish i could tell you an easy way because i would
Aug 21, 2007 at 7:59 AM
