Coil Pack?
RYKNOW
  • 5 POSTS
This question is still concerning the topic under Engine Trouble. Could it possibly be my coil pack over-heating? The Coil Pack is located on top of right hand side close to the exhaust manifold. And also very close to the transmission. :x
Nov 16, 2007 at 11:52 AM
TOBYU
  • 89 POSTS
It is unlikely that a contour coil pack in overheating....you should see the placement on an aerostar..
What are the symptoms?
If it dies when hot...it would more likely be a CPS crank position sensor than a coil pack..
Ignition modules are also know to get how and break down until cool...
I would have to look up the ignition system in the contour to see about the module though...
Nov 16, 2007 at 12:39 PM
