1998 Ford Contour Overdrive Light Blinks
CHUCK5613
I am having trouble with the tranny on my 1998 Ford Contour (4cyl.) 145,000 miles. The overdrive no longer engages. The overdrive light continually blinks. The transmission shifts hard from first to second and sometimes just slips and spins revving the motor and losing momentum. The problem has been slowly escalating over the past several months, but seemed to fully present itself "suddenly" about six weeks ago. The car is still being deriven although it has also developed an additional problem of stalling. Please help.
Dec 29, 2006 at 3:21 PM
TAURUSWHEEL
  • 718 POSTS
Stall when you come to a stop?? Could be a torque converter lockup issue, Get an auto parts shop to read your computer, make sure you get the codes from them, some trans issues will definitely show up as a fault..
Dec 30, 2006 at 6:32 AM
Suggested Repair
Have an auto parts shop scan the computer and retrieve any transmission fault codes. A blinking overdrive light with stalling at stops may point to a torque converter lockup issue.
Conversation Summary
The owner of a 1998 Ford Contour reports that overdrive no longer engages, the overdrive light blinks continuously, shifts from first to second are hard, and the transmission sometimes slips and revs. The car has also begun stalling. The expert asks whether it stalls when stopping, suggests a possible torque converter lockup issue, and recommends a computer scan for fault codes.
