ABS problem
CLC361
Ford, Contour, V-6, 1996, 38K.
ABS light on. Brake mechanic cannot read code or find problem yet.
Three times when coming to a stop the light will go out, car feels like it will not stop, but does in time. Makes a grinding noise. Light then goes back on.
No other problems known.
Bad sensor? Bad connection? Or what?
Apr 19, 2006 at 9:17 AM
LOSONE
  • 1,616 POSTS
grinding noise is usually VERY worn brakes which will light the ABS light. May be on the rear and the mechanic doesn't want to pull the rear drums Let me know
Apr 19, 2006 at 11:12 AM
CLC361
Wife just said it happen four times today!
Slight correction to the symptoms, the light goes out, the brakes seem to be grabbing with a slight growl, and then there is a complete stop and then the light comes back on after about 3-4 blocks.
Shop closed now, but thought he said he pulled all wheels.
Apr 19, 2006 at 12:58 PM
