1998 Ford Contour Lost All Gears
WEN
my 98 ford contour with a 2 litre engine automatic tranmission 192 thousand kilms i was driving it and all of a sudden i lost all the gears now i have nothing any help would be great thank you
Jun 16, 2007 at 11:28 AM
98RANGERXLT
  • 301 POSTS
Sounds like transmissions out
Jun 17, 2007 at 11:29 AM
SHELBYGT
  • 56 POSTS
i guess cut the floor out and be like fred flinstone and yell yab adoo nah just joking but see if you have any fluid in your transmission and if u do then you might be like fred because your transmission is most likley gone
Jul 17, 2007 at 5:50 PM
Suggested Repair
Check the transmission fluid level. If fluid is present, the transmission has likely failed and will need repair or replacement.
Conversation Summary
The owner of a 1998 Ford Contour 2.0L automatic with about 192,000 km suddenly lost all gears while driving. Replies indicate the transmission is likely failed and advise checking the fluid first; if fluid is present, the transmission is probably gone.
