2000 Ford Contour wont start
ROCK42067501
2000 Ford Contour 4 cyl Front Wheel Drive Automatic
i have a 2000 ford contour and it wont start acts like it not in park to start is there some sensor or something in there that effects it because some time i can shake it around or take it and shift it in low then put it back up into park it will start have any ideals
May 5, 2008 at 5:22 PM
BMRFIXIT
  • 19,053 POSTS
You have a neutral safety switch
check battery
check battery terminal and connections , clean and tighten if needed
check alarm system if equipped
check starter and its connectors
check small wire at the starter
May 6, 2008 at 10:22 PM
