2000 Ford Contour transmission issue
12,600 MILES • 6 CYL • 2WD • AUTOMATIC
JAIMIELYNN1978
Okay I have a 2000 contour when it gets over 40 mph it has troubles shifting into a higher gear. Will changing the fluid and filter on it fix the problem or am I doing more harm
Nov 28, 2008 at 6:36 AM
DOCFIXIT
  • 18,828 POSTS
Degraded fluid can cause problems a change is never a bad idea.
Nov 29, 2008 at 6:41 AM
