2000 Ford Contour too much oil
16,000 MILES • 4 CYL • FWD • AUTOMATIC
RADIO_NOIZ
I believe I over filled my engine oil. What should i do now?
Jul 18, 2009 at 1:07 PM
  • 31,937 POSTS
Hi there,
Check the level first, if it is just over the mark that is not a problem, but if it is well above the full mark you will have to drain some from the sump, there is a drain plug that will unscrew at the bottom of the engine sump, drain out the excess oil and replace the sump washer as well, best to drain the lot and start again, you can use the old oil, just make sure that you use a clean drain tray.
Mark (mhpautos)
Jul 18, 2009 at 1:59 PM
