2000 Ford Contour Timing Belt
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTT07054
recently my car stalled as I was driving, it would not start back up. it was towed to a mechanic shop. They have told me now that the timing belt broke, and they preformed a "leak test" on it to see if the valves are bent, which they say are. I am looking at a 2000.00 billl according to the shop. Are they right? How could they valves be bent so abrubtly? or am I getting rippef off? Please help!!!
Apr 22, 2008 at 4:23 PM
MOPARNUT1393
  • 34 POSTS
if it is a in Interference fit engine (timing belt breaks, valves slap pistons either bending valves or punching holes in pitstons)
than it could be that expensive. I would shop around to other mechanics and see what others charge or you may look at replacing engine with a long block reman or low mileage salvage yard engine but when going with that option you would want to have timing belt changed before it goes in the car.
Most of these contours have a common ford engine and I would price it either way.
If you like the car and it is in good shape than it may be worth what ever route you choose but look at your options and maybe look at a different car and see if its really worth repairing this one.
Apr 22, 2008 at 4:43 PM
