2000 Ford Contour thelights are coming on.... but the engin
105,800 MILES • 6 CYL • 4WD • AUTOMATIC
PISITOM
The lights are on...but the engin would not start....changed the batterry.. put a new one but still.....
Mar 14, 2010 at 7:09 AM
  • 75,988 POSTS
Pick your symptom:
**Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Mar 14, 2010 at 9:37 AM
