2000 Ford Contour rough idle
149,000 MILES • 4 CYL • 2WD • AUTOMATIC
WOOFWOOF1025
Im certain the intake manifold gasket is the source of problem. Is there any words of wisdom or warnings in this what seems like a simple repair.?
Sep 12, 2010 at 3:47 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Sep 12, 2010 at 3:54 PM
