2000 Ford Contour Reeving
103,000 MILES • 6 CYL • FWD • MANUAL
ROB52105
While driving the car on occasion the moror will rev without pushing the accelulator. If i apply the clutch the motor will rev even higher. It dosnt happen all the time however when it does it is very ansafe to drive.
Thank you
Jun 9, 2008 at 12:16 PM
SERVICE WRITER
  • 9,123 POSTS
There may be a vacuum leak present that is raising the idle. Check your vacuum to see if it is in spec when the problem happens.
Jun 9, 2008 at 12:45 PM
