Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Contour
Drivetrain
Transmission
Gear Position Sensor
Replace/Remove
2000 Ford Contour range sensor
2000 FORD CONTOUR
120,000 MILES • 6 CYL • FWD • AUTOMATIC
RWBJR
MEMBER
1 POST
How do I change the range sensor on my 2000 ford contour?
Oct 4, 2008 at 6:51 AM
BMRFIXIT
Experienced Mechanic
Remove shifter and remove nut remove mounting bolts remove switch need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 15, 2008 at 2:15 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
