2000 Ford Contour Possible ignition switch problem
SNIEMOJUSKI
2000 Ford Contour 6 cyl Front Wheel Drive Automatic 148k miles
Since it has been cold here in Wisconsin, i have been having issues starting my car. it really only happened when it was cold, but now it is happening all of the time. When i go to start my car, i put the key in the ignition and turn it to start/turn the engine over. the radio, the lights (interior and exterior) and the dash lights come on, but the car will not turn over. i usually either have to leave the key in the ignition turned to the a/c and wait for the windshield wipers to go on before i can turn it over. the automatic windows will not roll down, windshield wipers or anything with a motor will not power. i have a brand new battery which is obviously not the problem. I'm thinking it may be an ignition switch problem. I have taken my car in but of course, it doesn't do this after the car has been started and running for a while. and sometimes even after i get it started, the engine dies and i have to wait again for the windshield wipers to go on before it will turn over. why is this happening.. its quite annoying. thank you
Mar 10, 2009 at 3:03 PM
BMRFIXIT
  • 19,053 POSTS
Check battery terminals
clean and tighten
check the ground wire at the back of the starter
Mar 16, 2009 at 12:56 PM
