Fuel pump wiring - Inertia switch?
140,000 MILES • 4 CYL • FWD • AUTOMATIC
LATINMECANIC
hi . when l drive this car first l start the engine starts good but it takes like 5 min and gas shut off the car get off, but if l push the gas pedal ready to drive the car dont get shut off the problem is when l stop in a red light the car starts shaking and sometimes the fuel stops or it has a problem with the pressure. The wiring or inertia switch?
Aug 20, 2010 at 6:02 AM
WRENCHTECH
  • 20,760 POSTS
It could be both but to be sure here is the fuel pump and engine wiring so you can see how the system works with the inertia switch location as well. Check out the diagrams (Below). Please let us know what happens.
Aug 20, 2010 at 6:38 AM
LATINMECANIC
[quote:bd7ff45c50="Wrenchtech"][quote:bd7ff45c50]hi . when l drive this car first l start the engine starts good but it takes like 5 min and gas shut off the car get off, but if l push the gas pedal ready to drive the car dont get shut off the problem is when l stop in a red light the car stars shakeing and sometimes the fuel get stock or it has a problem with the pressure[/quote:bd7ff45c50]
I don't know what language your speaking but it's nothing but meaningless words jumbled together.[/quote:bd7ff45c50]
Aug 20, 2010 at 7:06 AM
TYWALT62
Car turns over will not start,I don't know where the reset button is for the fuel pump? could it possible be the timing chain?
Aug 29, 2020 at 4:22 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
The inertia fuel shutoff switch is located behind the left cowl side (kick) panel. Access to the switch is through an opening in the trim panel.
TYWALT62
Thanks Wrenchtech,I tried the inertia switch still won't start any suggestions would be appreciated
WRENCHTECH
  • 20,760 POSTS
I don't know how you landed at the fuel pump in the first place.
Here is what you need to do.
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
4) If all of these things check good, then you would need to do a complete compression test.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
AL
fuel pump shut off switch triggered,how do i reset?
  • 110,246 POSTS
On a ford, it is nothing more than a reset button. I believe the contour has one in the Left kick panel (Drivers side by your feet)
See diagram below
WRANGEL22
why does car have gas shut off switch? and will it keep car from starting?
Aug 29, 2020 at 4:23 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
it is a safety feature in case the vehicle is in an accident, it will shut off the fuel supply to prevent a fuel fire. if it is faulty then yes it can prevent the vehicle from starting.
