2000 Ford Contour Ignition Cylinder
RAYMAN19862004
2000 Ford Contour 4 cyl Two Wheel Drive Automatic
My brother broke his key off in his ignition. We have drilled out the old cylinder and are trying to place the new one in but it doesn't seem to be connecting right? Am i missing something?
May 14, 2008 at 4:09 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:1a7fa53302="rayman19862004"]2000 Ford Contour 4 cyl Two Wheel Drive Automatic
My brother broke his key off in his ignition. We have drilled out the old cylinder and are trying to place the new one in but it doesn't seem to be connecting right? Am i missing something?[/quote:1a7fa53302]
Well I guess that depends on what you mean by Drilled Out. If it means that you used a drill and bits, Your in Trouble.
In most cases in order to change the lock cylinder you have to take the steering wheel off.
May 18, 2008 at 12:28 PM
