2000 Ford Contour engine runs rough at idle
67,000 MILES • 4 CYL • FWD • AUTOMATIC
BLUERIDGEMAN
engine runs rough at idle,also were is the pcv valve located on this engine?..thankk you..
Apr 17, 2010 at 2:46 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following-inspect and test all the following below: 1.Defective spark plug. 2.Inadequate spark/coil,defective spark plug wire. 3.Lack of compression 4.False air leakage. 5.Faulty fuel injectors. 6.Insufficient fuel pressure. 7.Contaminated fuel. 8.EGR valve that is leaking. 9.Oxygen sensors. 10.Throttle position sensor. 11.Idle air control valve.
https://images.2carpros.com/forum/automotive_pictures/12900_pcv_2.gif
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Apr 22, 2010 at 6:32 PM
