2000 Ford Contour ELECTRIC WINDOWS
2000 FORD CONTOUR
92,000 MILES • 6 CYL • FWD • AUTOMATIC
SECONDARY
WINDOW IS STUCK IN THE DOWN POSITION.
MOTOR WILL STILL RUN WHEN THE UP/DOWN SWITCH IS PRESSED. IS A SPECIAL TOOL REQUIRED TO REMOVE DOOR PANEL.
I HAVE ABILITY TO WORK ON CARS OR IS THIS TO DIFFICULT TO REPAIR.
Jul 8, 2010 at 2:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Open the door you want to take apart. Ensure the window is rolled up.
Locate the screw in the driver latch assembly. Take the screw out with a Phillips head screwdriver. Pull the trim out and around door the handle. Disconnect the wiring in the back of the trim. This will be the power seat controls. Place the trim to the side.
Pry the seat control panel gently with a flat head screwdriver. Disconnect the wiring by pulling the connector off the back of the switch.
Locate the screw on the side of the door panel. The screw is on the unexposed side of the door. Unscrew it with a Phillips head screwdriver.
Lift the panel out gently. Inspect the back of the panel for any wiring that may still be connected. Disconnect any wires.
Place the panel to the side. This will expose the door assembly.
Jul 8, 2010 at 6:42 AM
SECONDARY
THANK YOU VERY MUCH FOR THE INFORMATION IT WAS VERY HELPFULL
STEVE
Jul 8, 2010 at 7:08 AM
