2000 Ford Contour contour svt will not start
11,400 MILES • 6 CYL • FWD • MANUAL
FORDGTD1
manual car, replaced starter, all accessories work,; turn key no sound, no click; no power to starter
Apr 7, 2009 at 12:32 PM
BMRFIXIT
  • 19,053 POSTS
check clutch position switch
Apr 8, 2009 at 11:40 AM
FORDGTD1
you mention clutch position switch; where is it located? Under pedal? Does ths switch go bad or can it be adjusted?
many thanks
richard
Apr 8, 2009 at 2:21 PM
BMRFIXIT
  • 19,053 POSTS
I’m not sure of adjustment
I know it should have continuity when clutch peddle down
check it out
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Apr 8, 2009 at 10:49 PM
