2000 Ford Contour Check engine light
2000 FORD CONTOUR
100,000 MILES • 6 CYL • FWD • AUTOMATIC
KEVINDANA
My mother in law has a 2000 Ford Contour with a 2.5 v-6. The check engine light keeps coming on and sometimes no performance is lost but occassionaly it stalls but will start back up. Codes are 171,174,190. Fuel pressure is fine as is the regulator. I replaced the upstream o2 sensor and it helped for about 2 weeks. What is fuel rail pressure sensor circuit malfunction(code 190)?
Feb 8, 2008 at 1:18 PM
BMRFIXIT
  • 19,053 POSTS
[quote:e036da4395="kevindana"]Engine problem
2000 Ford Contour 6 cyl Front Wheel Drive Automatic 100000 miles
My mother in law has a 2000 Ford Contour with a 2.5 v-6. The check engine light keeps coming on and sometimes no performance is lost but occassionaly it stalls but will start back up. Codes are 171,174,190. Fuel pressure is fine as is the regulator. I replaced the upstream o2 sensor and it helped for about 2 weeks. What is fuel rail pressure sensor circuit malfunction(code 190)?[/quote:e036da4395]
its vacuum leak
you have to located
Feb 8, 2008 at 1:21 PM
