I have a 1999 Ford Contour with about 89,000 miles on it...i recently replaced my timing belt but lately my car has been having problems starting, which is an on again off again problem. The other day my check engine light came on and there seems to be excessive fumes coming out of my exhaust from time to time.
My mechanic tested my igntiion and starter and all was fine. He ran a diagnostic test and got the code: P1383 Variable Cam Timing Over-retarded (Bank 1) (Ford) but couldnt pinpoint the problem.
Can you tell me what this means, what needs to be fixed, about how much it could run me and if it is safe to drive for a few days while i schedule an appointment and ride to work?
thank you
thank you
Nov 19, 2006 at 11:03 AM
