1999 Ford Contour variable timing cam adjustment
201,000 MILES • 4 CYL • FWD • AUTOMATIC
GOUCHOMAN
I have replaced the head gasket and now need to re-install the cams. My exhaust cam has a variable timing sprocket that need to be set. How do I do this and what is the torque for the sprocket bolt?
Aug 26, 2008 at 2:08 AM
2CARPRO JACK
  • 11,533 POSTS
Your best bet will be to go here
https://www.2carpros.com/manuals.php
Go to "engines" then timing belt and follow the step by step instructions. Easier for you to read and see the pics than for me to try to walk you through it, dont want to mess anything up at this point in the project
Aug 28, 2008 at 1:03 AM
GOUCHOMAN
There is a link, but it doesnt answer any part of my question. It only refers me to another page that wants me to by a subscription. I feel your answer is a complete failure and an attempt to get more money out of me by referring me to a page to subscribe to your online manual. Please prove me wrong by actually providing me some info on the issue!
David P
Sep 3, 2008 at 5:15 AM
THIS IS MIKE
  • 686 POSTS
The information provided by our tech showed you where to find the technical information you need in order to reassemble your engine properly. The online manuals are less than $10 and have factory specifications for your exact engine. We have refunded your donation.
Sep 5, 2008 at 6:25 AM
