1999 Ford Contour Studder/Stall upon Deceleration and at Id
CONTOURISSUE
  • 1999 FORD CONTOUR
  • 6 CYL
  • 150,000 MILES
Car has the 2.5L V6. All o2 sensors were recently replaced (within a few months, for unrelated issue). Car began studdering/shaking/sometimes stalling when slowing down or stopped and the rpms got got lower yesterday. Previously replaced the iac valve to fix the same issue a few years ago with success. Replaced it yesterday and the problem improved but still had a slight shake, problem reappeared worse today and is hard to keep car running when slowing down or stopped. ECU gave codes P0171 and P0174 when scanned yesterday.
Tuesday, January 5th, 2010 AT 11:19 PM
  • 109,755 POSTS
PO- 171 Fuel Trim System Lean (Bank 1)
PO- 174 Fuel Trim too Lean (Bank 2)
What I think you're looking for is a vacuum leak. Have you checked? Also, check around the intake.
Let me know what you find.
Thursday, January 7th, 2010 AT 9:02 PM
