1999 Ford Contour Repair cost
100,000 MILES • 4 CYL • 2WD • MANUAL
LILLIEMYOUNG59
I was told that I need to replace my car shruts/shocks. My question is are they the same or do I need to replace one and not the other or do they come together as an combine unit. please advise
Jan 11, 2009 at 11:05 AM
DAVE H
  • 13,383 POSTS
rear struts $115 each front struts $98 each Front suspension is MacPherson strut type, using gas pressurized struts and cast steering knuckles. Strut assembly is bolted to top of strut tower. Lower end of strut fits into a pinch joint, designed into the steering knuckle. A stamped steel control arm attaches to subframe and steering knuckle at lower ball joint. A link assembly runs between the strut and stabilizer bar end. See Fig. 1 . Installation of new front strut assemblies and/or springs in pairs is not required by manufacturer. Install front suspension assemblies and/or springs one at a time as required. Fig. 1: Identifying Front Suspension Components Courtesy of FORD MOTOR CO.
https://images.2carpros.com/forum/automotive_pictures/266999_strut_1.jpg
Contour, Cougar and Mystique use a MacPherson strut independent rear suspension. Each side consists of a gas-pressurized shock absorber strut assembly, 2 parallel control arms, tie rod, forged spindles, shock bumper, and dust shield. See Fig. 1 .
https://images.2carpros.com/forum/automotive_pictures/266999_strut_2.jpg
Jan 11, 2009 at 11:14 AM
