1999 Ford Contour Rear struts
JOSHWARD35
Suspension problem
1999 Ford Contour 4 cyl Front Wheel Drive Automatic
Is there a way to tighten nut on top of rear strut while on vehicle. just wonder cause put strut in vehicle already and nut was tight I thought, but could use a few more turns. Got socket on bolt but the strut shaft just spins.
Oct 29, 2010 at 11:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
will have to find something to rig up to hold the shaft otherwise it will have to be removed
Oct 29, 2010 at 11:52 AM
