1999 Ford Contour overheating
150,000 MILES • 4 CYL • FWD • AUTOMATIC
TULSA EV
The car started overheating (105 degrees temp outside). Fluids all look okay. The heater works, a/c doesn't cool.
Where is the thermostat? I don't see any fluids leaking from below the car either.
The thing won't run on the mixed blend fuels. I did have to put a couple gallons in last week until I could get to my regular gas station. Could that do it?
Aug 4, 2008 at 2:13 AM
BLACKOP555
  • 10,386 POSTS
if you were running incompatable fuel in the vehicle it could most certainly overheat.
thermostat should be at the bottom radiator hose in the housing.
Aug 4, 2008 at 3:26 AM
