1999 Ford Contour Missing
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCHWEER
My 1999 Ford Contour with 160,000 miles has a weak idle, like it may just die unless i push on the accleator, and when I am acclerating on the highway it feels like the car is dragging and missing some of its power. When i turn off the engine there is a chemical smell as well. Any advice you could give me would be greatly appreciated.
Apr 5, 2010 at 10:59 AM
  • 75,988 POSTS
Clean out the idle air control valve, EGR valve and also clean the MAF sensor with an approved cleaner and see what happens-also test the throttle position sensor.
Apr 5, 2010 at 11:58 AM
