1999 Ford Contour Leaking Oil
99,000 MILES • 6 CYL • FWD • MANUAL
DCTOTTYDC
My '99 Contour SE V6 has 99,000 miles, runs great, but has been leaking oil recently. I was told to have the oil pan gasket replaced, did so and it still leaks. I have now been told the "main seal" may be bad. It is a slow leak but I need to get it fixed asap. If there are any characteristics of the car due to age/rust (it is from NY) any advice would be much appreciated. Thanks.
May 26, 2008 at 2:45 PM
  • 31,937 POSTS
Hi there,
if you have a leak from the rear of the engine and you have had the sump done, it is a fair chance that the rear main is leaking. I would give the engine a good wash down and take it for a drive, Have a good look around the rear of the engine, also the rocker covers just make sure that there are no higher leaks running down. Dom this first.
Mark (mhpautos)
May 26, 2008 at 3:35 PM
