1999 Ford Contour insufficient flow to the egr
SMOKETHELOC
  • 5 POSTS
1999 Ford Contour 6 cyl Front Wheel Drive Automatic
i recently fail a smog test due to egr. i replaced the egr valve the egr exaust gas pressure differential sensor. how do i clean out the whole exaust system?
Jul 3, 2009 at 6:03 PM
BMRFIXIT
  • 19,053 POSTS
What was the code ?
most I ve seen DPFE sensor no good
also check for clogged intake manifold side of the egr
check for an leaks also
good luck
Jul 3, 2009 at 9:56 PM
SMOKETHELOC
  • 5 POSTS
the code was p0401 insufficient flow to the egr
Jul 8, 2009 at 4:51 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_203.jpg
Jul 9, 2009 at 1:19 AM
