1999 Ford Contour Help in San Antonio
1999 FORD CONTOUR
168,100 MILES • 4 CYL • 2WD • AUTOMATIC
SAMANTHALSG
AI just got my car serviced. Replaced the water pump, timing belt, idle pully's, v-belt, and oil change. Now that I picked up the car the car o/d off light is on and blinking and it won't switch to third gear. I have had NO problems with this and now that I had work done, this is happening. Is it something that they could have done?
Feb 21, 2009 at 4:38 AM
DOCFIXIT
  • 18,828 POSTS
they may have not hooked up crankshaft position sensor or it was damaged in repair.
Feb 21, 2009 at 6:55 AM
