1999 Ford Contour grinding noise
150,000 MILES • 4 CYL • FWD • AUTOMATIC
STRIGHT737
Our Ford contour makes this grinding noise up front from the tire area while driving. It started when turning but now does it whenever you drive. We have stopped driving it but want it fixxed. Our diagnosis was a worn out CV Joint is this correct? If not what is wrong with it?
Aug 28, 2010 at 7:44 AM
DOCFIXIT
  • 18,828 POSTS
Most likely the wheel bearing
Aug 28, 2010 at 7:46 AM
