1999 Ford Contour FREEZE PLUGS
1999 FORD CONTOUR
WESLEYH
Engine Cooling problem
1999 Ford Contour 4 cyl Front Wheel Drive Automatic alot miles
i own a 99 countour se and it is leaking coolant from somewere on the block as far as i can tell i am just trying to find out if it could be the freeze plugs or something much more serious
Jun 3, 2010 at 11:56 PM
  • 31,937 POSTS
Hi there.
Get a mechanic to do a cooling system pressure test, this will locate any external coolant leaks, start here.
mark (mhpautos)
Jun 4, 2010 at 7:07 AM
