1999 Ford Contour Fan relay
JOHN VINTI
  • 11 POSTS
Where can I find the resistor relay that controls the speed of the dashboard fan on a 1999 Fod Contour? Are there any difficulties or tricks you can help me with in swapping out this part? the car has 89,000 miles
Aug 19, 2006 at 8:39 AM
NOS
  • 320 POSTS
look behind the glove box, best way to locate it is find the blower motor. trace the wires back to the resistor. there is a blower relay, and a blower resistor and sometimes a blower module and it is know as a resistor either way there mounted inside the blower box so they can stay cool they have to have air blowing on them. hope this helps. ( NOS
PS if your having trouble with blower speeds check the switch alot of times i see burned up wiring due to blower load.
Aug 20, 2006 at 2:57 AM
