1999 Ford Contour Excessive fuel consumption
Z28WILL0
I have a 1999 ford contour with a 2.5l v6 with 127000 kms, and i am currently only getting apprx 300 kms to the tank. What could be causing the fuel to be used up so fast?
Apr 14, 2007 at 8:51 AM
  • 75,988 POSTS
[quote:a75f6f7819="z28will0"]I have a 1999 ford contour with a 2.5l v6 with 127000 kms, and i am currently only getting apprx 300 kms to the tank. What could be causing the fuel to be used up so fast?[/quote:a75f6f7819]
Try getting a major tune-up and change the oxygen sensor/s
Apr 14, 2007 at 9:01 AM
SHELBYGT
  • 56 POSTS
it could be a dirty air filter
incorrect ignition timing
low tire pressure or wrong tire
fuel injection sytem going bad
Jul 17, 2007 at 6:00 PM
