My engine surges at idle on my 2.5 V6 and will sometimes stall. I have had the engine light codes checked and it said EGR valve, IAC, Oxygen sensors, and a few more. I have replaced the EGR, IAC, and both oxygen sensors and the engine is doing the same thing. The check engine light is still on but I haven't had the codes rechecked. I have exhuastedly checked for a vacuum leak and have found none. I'm out of options. The car runs fine when it isn't idling. Where do I go from here?
Feb 4, 2008 at 10:03 AM
