1999 Ford Contour crankshaft problem
130,000 MILES • 6 CYL • FWD • AUTOMATIC
MEHRBOD
We are in the process of a timing belt replacement(due to lack of money). Everything is installed and now we are ready for the process of timing the two camshafts(gears) with the crankshaft(harmonic balancer)...However, the crankshaft is frozen in place and we cannot rotate the crank even with lubrication in each cylinder head and transmission in neutral. What is preventing the crankshaft from turning in the clockwise direction?
Thank You for your input,
M.Mehrbod
Sep 22, 2009 at 8:09 AM
  • 75,988 POSTS
Could be the main bearings seized to the crank journal
Sep 22, 2009 at 8:52 AM
