1999 Ford Contour Car Alarm
1999 FORD CONTOUR
14,600 MILES • 6 CYL • FWD • AUTOMATIC
JENNVINTIGNI
My battery died due to my lights staying on, we jumped the car and had to reset the alarm to get the car to start. Now my alarm won't let me restart the car and I can't get my keypad to work, I have to hit the reset button every time.
Oct 3, 2009 at 1:28 PM
BMRFIXIT
  • 19,053 POSTS
If it is a factory alarm do this
open driver side window
disconnect the battery
place key in ignition and turn key ON
reconnect the battery that should reset the after market alarm
If it is an aftermarket alarm it needs to be replaced.
Oct 4, 2009 at 10:33 AM
JENNVINTIGNI
Now I have to press the reset button on the alarm underneath my dash in order ot start my car on my contour? My key pad doesn't work can this be fixed? This has never happened when my battery needed to be jumped.
Oct 4, 2009 at 2:00 PM
BMRFIXIT
  • 19,053 POSTS
When battery dies ,alarm automatically default to active
The procedure I gave did nt work ?
try this if not
turn and turn key on cycle alarm switch on off
turn key off and try to start
Oct 4, 2009 at 2:12 PM
JENNVINTIGNI
I will try this, its a factory alarm thats why we are so confused.
Some of your directions don't make sense can u send them again?
Oct 4, 2009 at 2:18 PM
BMRFIXIT
  • 19,053 POSTS
Its not a factory alarm
factory alarm do not have a reset switch under the dash
open a window (so you do not get locked out the car )
open hood (so you can disconnect the battery )
disconnect battery negative side and set aside
place key in the ignition and turn the key to on ( not start )
make sure all door shut
if that did not work
with battery connected
turn key on cycle alarm reset switch on off
turn key off
start engine
if its a factory alarm
place key in driver door lock and lock and unlock the door
that will reset the FACTORY ALARM
Oct 4, 2009 at 10:39 PM
  • 55,224 POSTS
It sounds like the alarm needs to be replaced.
Feb 5, 2017 at 7:08 PM
