1999 Ford Contour Brake Pedel studdering/pulsating
98,500 MILES • 4 CYL • AUTOMATIC
NOKE0301
Often when I am coming to a complete stop, I will feel the brake pedel pulsate or studder a few times. The feeling is similar to when ABS brakes are working on a slippery road surface. But this occurs frequently (but not consistently) on any surface. Not sure if it is a problem with the ABS, the roaters or brake pads, or something else.
Jan 18, 2008 at 8:52 AM
MASTERTECHTIM
  • 4,750 POSTS
what is happening is 1 wheel speed sensor is dropping out when you are stopping. very easy to check. have your mechanic drive it with his scan tool on, he can watch the wheel speeds.
Jan 18, 2008 at 8:54 AM
