1999 Ford Contour Blower will only run on high
1999 FORD CONTOUR
JMP54
Air Conditioning problem
1999 Ford Contour 6 cyl Automatic 50000 miles
My A/C and heat work fine but the fan will only work on high. Any setting in between off and high does nothing. Is this something I could correct myself. I am a senior citizen, widow on a VERY limited budget.
May 9, 2008 at 9:23 AM
Get the blower motor resistor checked out, this is the one that controls the speed of the blower motor-
May 9, 2008 at 10:02 AM
