1999 Ford Contour alternator replacement
176,288 MILES • 4 CYL • FWD • AUTOMATIC
ATRAVELINGPILGRIM
have removed 2 long bolts thru alt frame, removed major output connection, removed resonating chamber(for access as per Haynes), but cant get tension off belt. has idler in front of alt and tensioner below. belt it tite. cant find anything to pry against to ease tension. help...sitting still cause car wont go..mike
Jun 12, 2010 at 5:41 AM
  • 110,248 POSTS
Here is a diagram of the belt which includes where the automatic tensionier is located. Let me know if it helps.
https://www.2carpros.com/car_repair_information/year/1999/make/ford/model/contour/1999_ford_contour_drive_belt_routing_diagram.htm
Jun 29, 2010 at 5:51 PM
