1999 Ford Contour Alternator
KRSHEFFIELD
Engine Mechanical problem
1999 Ford Contour 4 cyl Front Wheel Drive Automatic
My moms alternator went out we had it rebuilt put it on and the car would die in idle..so we took it to a shop ran scan and found out the cam and crankshaft sensors needed to be replaced now the car will run fine as long as the alternator is unhooked and we have been advised to get another alternator yet we have had this one check and they say its fine... we are stumpted..any one have any suggestions on what might be wrong.
Oct 11, 2009 at 12:32 PM
FIXITMR
  • 9,989 POSTS
you can get 1 cheaper from junk yard if you want to try it?
Oct 19, 2009 at 1:24 PM
