1999 Ford Contour Advice, tips, wisdome and Input for head
160,000 MILES • 4 CYL • FWD • AUTOMATIC
EDDYMORR
  • 12 POSTS
If you have done a head gasket replacement on this car please share your expereince.
I have never wrenched this deep into any engine. I will be removing the intake and exhaust manifolds to replace those gaskets. I have three repair manuals and a free weekend.
I need the following to do the job:
Replacement Head gasket kiit
New Cylinder head bolts
A torque angle gauge
gasket scrapper
coolant
I will also replace
Timing Belt
Tensioner
spark plugs
Manual say I need to fabricate two tools:
Alignment Rod 0.20 inch thickness 7 to 9 inches in length 1 and 1/4 inch wide
Sprocket Holding Tool
23.5 inch length steel strip
8 inch length steel strip
3 bolts and nuts with washers
Concerns:
any possible hangups or problems
Thanks
Dec 11, 2008 at 10:32 AM
DAVE H
  • 13,383 POSTS
just a bit of friendly advice .. take your time and get it right ??
Good luck ... Dave H
CAUTION:Maximum amount of by which the engine management system will adjust the camshaft timing (VCT control unit) is limited to two degrees. As a result of this an extremely high degree of accuracy is required for any work which affects the valve timing.
Dec 11, 2008 at 12:16 PM
BMRFIXIT
  • 19,053 POSTS
May I suggest spending $20 and buy a tool kit OTC Tools OTC6486 Ford Cam Tool Kit do it right with the right tool less headache for you good luck
https://images.2carpros.com/forum/automotive_pictures/99387_Untitled1_3.jpg
Dec 11, 2008 at 1:51 PM
EDDYMORR
  • 12 POSTS
Thanks. THe advice is appreciated
Dec 12, 2008 at 10:39 AM
EDDYMORR
  • 12 POSTS
I've found two different sources of information for installing the head cylinder bolts. One manual says to install them dry, while the other states to oil them. I'm more inclinced to oil them.
2.0 4 cylinder 1999 contour.
Also, what shape was the original gasket on the oil seperator? Did it cover just the central area or did it cover the whole mount area? I could not tell where the old gasket began and ended after I cleaned it off.
Thanks
Dec 19, 2008 at 2:21 AM
DAVE H
  • 13,383 POSTS
l'd be installing them dry .. my manual does not state either way, so that would mean dry ... ? you geting a better torque setting dry ?..
I don't understand what you mean "oil seperator" ??
Dec 19, 2008 at 3:54 AM
EDDYMORR
  • 12 POSTS
Car was built in April 99. The oil separator is right behind the Exhaust manifold, mounts into engine block. The PCV valve mounts into it. The original gasket is gone. I cleaned up the caked on carbon, oil etc but, I can't make much sense of what the original gasket's shape had been. It either had a triangle type shape or was a simple circle gasket. Maybe doesn't matter?
Dec 19, 2008 at 5:58 AM
EDDYMORR
  • 12 POSTS
Where is the hole the bolt from this kit fits into? I could use some direction here? Is it near the fly wheel, crank pulley or under a cylinder? Thanks Eddy
Dec 19, 2008 at 12:04 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Untitled_6.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Untitled_7.jpg
Dec 19, 2008 at 12:20 PM
DAVE H
  • 13,383 POSTS
Rotate the crankshaft clockwise to TDC cylinder No. 1. Remove the blanking plug, completely screw in the Crankshaft TDC Timing Peg (303-574, T97-P6000-A), and auto-align the crankshaft to TDC. See Fig. 10 .
https://images.2carpros.com/forum/automotive_pictures/266999_plug_1.jpg
Dec 19, 2008 at 12:22 PM
EDDYMORR
  • 12 POSTS
Hello again I'm not understanding the whole cam kit. I machined a flat piece of steel to keep the cams aligned. But the bolt has me at odds. Does it prevent the crankshaft from moving once properly aligned? Will I still need to jam the flywheel with a prybar? Thanks Eddy
Dec 19, 2008 at 12:49 PM
BMRFIXIT
  • 19,053 POSTS
This is why you need to buy the kit
the bolt is measured to make contact and hold the crank in place
Dec 19, 2008 at 1:06 PM
DAVE H
  • 13,383 POSTS
both pieces of kit will hold crank and cam in place
Hold camshafts with open end wrench. Turn the camshafts to ignition position on cylinder No. 4 and insert the Camshaft Alignment Plate (303-465, T94P-6256-CH) onto the ends of both camshafts. See Fig. 11 .
NOTE:DO NOT kink or bend the timing belt less than a diameter of 1.38" (35 mm). DO NOT rotate the crankshaft, and check that it is still resting against the timing pin. The lug of the belt tensioner must not be hooked into the sheet metal cover during timing belt installation.
Starting from the crankshaft timing belt pulley and working counterclockwise, position a NEW timing belt in place while keeping it under tension. See Fig. 12 .
Apply tension to the timing belt. Incorrect timing belt tension will cause incorrect valve timing. Rotate the tensioner locating tab counterclockwise and insert the locating tab into the slot in the rear timing cover. See Fig. 13 .
Position the hex key slot in the tensioner adjusting washer to the 4 o'clock position. Tighten the attaching bolt (3) enough to seat the tensioner firmly against the rear timing cover, but still allow the tensioner adjusting washer to be rotated using a 0.24" (6 mm) hex key.
Tension the timing belt, working counterclockwise. Using the hex key, rotate the adjusting washer counterclockwise until the notch in the pointer is centered over the index line on the locating tab (the pointer will move clockwise during adjustment). See Fig. 14 .
While holding the adjusting washer in position, tighten the bolt to specification. See TORQUE SPECIFICATIONS . DO NOT tighten the camshaft timing pulley bolts against the camshaft alignment plate. Use the camshaft sprocket holding tool to prevent movement. See Fig. 9 . The crankshaft must remain at TDC on cylinder No. 1. Tighten the bolts of the intake camshaft timing pulley to specification. Hold the exhaust camshaft by the hexagon with an open end wrench to stop it from turning. Tighten the exhaust camshaft timing belt pulley bolt.
Unscrew and remove crankshaft timing peg. Remove camshaft alignment plate from the camshafts. Turn the crankshaft 2 revolutions in the normal direction of rotation. Check the valve timing by inserting the crankshaft timing peg. Correct it if necessary.
Screw in crankshaft timing peg and make sure that the crankshaft is touching it. Insert camshaft alignment plate into the camshafts. If necessary, loosen the timing pulleys and correct the camshaft alignment. Remove the crankshaft timing peg and camshaft alignment plate. Screw in and tighten the blanking plug on the exhaust camshaft pulley.
NOTE:Coat the inside of the spark plug connectors with silicone grease to a depth of 0.20-0.39" (5-10 mm). Use a blunt object (such as a plastic cable tie) to apply the silicone grease, to avoid damaging the spark plug connectors.
Dec 19, 2008 at 1:08 PM
