1999 Ford Contour 1999 Contour stalls intermittently while
TERI1954
  • 5 POSTS
Engine Performance problem
1999 Ford Contour Automatic
Periodically, the engine on our son's Contour dies while he's driving. It occurs only when the road is wet. The first few times happened when there was a lot of slush on the road and today he hit a pothole full of water and the car quit. After a few minutes, it starts with no trouble. The repair shop ran diagnostics on it several times. Except for one time when the cam and crank sensors showed as a problem, nothing it coming up on the diagnostic. We had the timing belt replaced about two months ago and had the cam and crank sensors replaced last week. It sounds to me as though water/slush is shorting something out. However, the mechanics don't seem to think that's the problem. Help, please!!! We've had it at an independent repair shop and at a dealership and no one can figure out the problem.
Feb 20, 2010 at 5:40 AM
LEGITIMATE007
  • 5,121 POSTS
does this vehicle have and anti theft system?
Mar 8, 2010 at 4:20 AM
TERI1954
  • 5 POSTS
No, there isn't an anti-theft system.
Mar 8, 2010 at 4:39 AM
LEGITIMATE007
  • 5,121 POSTS
no type of alarm on this vehicle?
Mar 8, 2010 at 4:49 AM
TERI1954
  • 5 POSTS
No, there's no type of alarm at all.
Mar 8, 2010 at 5:23 AM
LEGITIMATE007
  • 5,121 POSTS
have your son check to see if there are any splash guards missing, because obviously these items are getting wet causing the vehicle to shut off, it may be getting the ignition module wet, . that is the only explaination I can give at this point, I've checked the technical service bulletins on this vehicle and it says something about the car shutting off in damp whether due to the harnass from the intermittent wiper motor being too close the the vehicles immobilizer, this is why I asked about the alarm
Mar 8, 2010 at 5:37 AM
TERI1954
  • 5 POSTS
The splash guards are okay. Neither repair shop has been able to figure it out. Both places drove it, trying to replicate the problem. They figured if it would die on them, they could find out what's wrong. The tech at the dealership sprayed the engine from the top and the bottom, drove it through their car wash full of slush and water and took it through every puddle he could find, but the car still wouldn't stall out.
Mar 11, 2010 at 10:09 PM
LEGITIMATE007
  • 5,121 POSTS
strange, I dont know what to say, I checked the tsb bulletins, nothing, and you know what,? I garauntee it is something so simple, that we cannot fathom it being the problem so it is being overlooked, the dealer should be able to put it on their specialized scan tool and recall all of the misshaps from months back I dont know why they wont do it, that is our only chance to figure this out. take it to another ford dealer, and see if they will put it on diagnostics and get the "freeze frame data" that is saved in the computer
Mar 11, 2010 at 11:29 PM
TERI1954
  • 5 POSTS
My husband talked to the mechanic at the dealership today and was told that they put it on the scan tool and ran the diagnostics. It didn't show anything. No one has any idea of what's wrong with the car. It's definitely been a frustrating experience.
Mar 12, 2010 at 12:26 PM
LEGITIMATE007
  • 5,121 POSTS
did you pay for them to put it on diagnostics? I would go somewhere else, and another thing is if they cannot duplicate the problem they will not waste anytime trying to chase it. I would still try to go somewhere else and explain what happened and see if they can pull the stored information out of the computer, that is one of the purposes of the computer, to record faults, so there has got to be something there to go on!!
Mar 13, 2010 at 12:50 AM
