1999 Ford Contour
BTAY
Air Conditioning problem
1999 Ford Contour 4 cyl Automatic 124000 miles
My car has been hooked up to a computer and the diagnostic keeps showing that there is no problem with my car at all. My check eingine light has never came on, but everytime my air or fan is on my car will shut off. It will start jerking, it will start driving slower and eventually stop driving while its still in drive and then shut off. If i wait 5 minutes it will come back on.My car runs fine when the air is off. I just found out I have a leak in my AC but a mechanic said that where its leaking wouldnt cause my car to shut off. Nobody knows why my car is shutting off only when the air is on. my pcv valve has been cleaned i got a new fuel filter and a number of other things fixed. the car hasnt had a tune up in a while but i dont know if thats the problem. Do you know why my car shuts off only when the air is on?
Aug 5, 2010 at 10:37 AM
  • 110,248 POSTS
Has the fuel pump pressure been checked?
Aug 9, 2010 at 5:56 PM
BTAY
no I dont think so, but it shut off again but this time my air and fan were not on...
Aug 10, 2010 at 7:21 AM
  • 110,248 POSTS
Here is a how to for checking fuel pump pressure. Check it and let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
NOTE: You will need a gauge. Most parts stores will lend or rent them to you.
Aug 10, 2010 at 5:13 PM
