1999 Ford Contour
177,000 MILES • 4 CYL • 2WD • AUTOMATIC
SULIE
I have a question about the charge on the battery. We have checked the battery and alternator they are fine and the car works fine until the battery's charge runs down. What is draning the battery? Thank you for your help
Jun 16, 2010 at 3:31 PM
  • 75,988 POSTS
Check mega fuse 175amp and fuses no.5 and 30 if so check for a short circuit that could be draining the battery-do battery drain test
https://images.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_220.jpg
Jun 16, 2010 at 5:58 PM
