1999 Ford Contour
SULIE
  • 1999 FORD CONTOUR
  • 4 CYL
  • 177,000 MILES
I have a question about the charge on the battery. We have checked the battery and alternator they are fine and the car works fine until the battery's charge runs down. What is draning the battery? Thank you for your help
Wednesday, June 16th, 2010 AT 10:31 PM
Check mega fuse 175amp and fuses no.5 and 30 if so check for a short circuit that could be draining the battery-do battery drain test
https://www.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_220.jpg
Thursday, June 17th, 2010 AT 12:58 AM
