1999 Ford Contour
1999 FORD CONTOUR
CARLTON481
Electrical problem
1999 Ford Contour Front Wheel Drive Automatic 140200 miles
engine turns over new wires coil fuil injectors work timeing belt ok 35 lbs fuil pressure want to but seems to flood out
Mar 31, 2010 at 4:06 PM
  • CAR REPAIR CONTRIBUTOR
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 23, 2010 at 1:38 AM
