1999 Ford Contour
KUDDLESS
Computer problem
1999 Ford Contour 4 cyl Front Wheel Drive Automatic
how do i remove my ecm
Jul 8, 2009 at 6:59 AM
BMRFIXIT
  • 19,053 POSTS
Powertrain Control Module (PCM)In right rear corner of engine compartment, behind power steering reservoir.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_201.jpg
POWERTRAIN CONTROL MODULE Removal & Installation Disconnect negative battery cable. Remove any component necessary to gain access to PCM. Loosen PCM connector retaining bolt (if equipped). Unplug harness connector from PCM. Remove 2 PCM mounting bolts. Remove PCM cover and PCM. To install, reverse removal procedure. good luck
Jul 9, 2009 at 12:39 AM
DSDS90
Excuse my ignorance but, ECM and PCM are same thing? I have a 2.0 liter M/T 1995 Ford Contour and have to replace the ECM
Mar 3, 2015 at 8:41 AM
