the dome lights, radio & power mirrors don't respond?
1999 FORD CONTOUR
100,145 MILES • 4 CYL • FWD • AUTOMATIC
PAMMIE
the dome lights, radio & power mirrors don't respond. Cleaned wiring loom under the battery, per Ford tech recommendation; checked 10 amp 12 volt circuit breaker & all fuses in cabin...no luck.
Oct 4, 2008 at 5:05 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi pammie,
Thank you for the donation.
Alll the components you mentioned gets it power supply from the #34 fuse (7.5 A) located in the cenral junction box, under left side of dash.
I believe it is blown.
Oct 5, 2008 at 10:11 AM
